It is currently Mon Aug 11, 2025 7:59 pm
PostPosted: Tue Apr 26, 2016 6:27 pm
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
I've finished building a thickness sander and have a problem. I ordered a roll of 2" self adhesive 80 grit
Paper as recommended by a couple of forum members. The adhesion has failed several times. The flapping will definitely get your attention. I made the discs from HDF and sealed the entire roller with a fast drying clear acrylic sealer from a spray can. I let it dry for several hours. No joy. I do recall someone using a Velcro set up, but can't locate it with Google. Can anyone steer me to the supplier? Thanks.
Brad Hall
Mystic Dawg Guitars
PostPosted: Tue Apr 26, 2016 7:16 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
https://www.woodworkingshop.com/search. ... loop+rolls
Try this or search for "hook and loop"
You might also consider having some type of clip to hold the ends of the paper below the surface of the drum. This way you could use regular rolls.( non psa or velcro)
PostPosted: Tue Apr 26, 2016 9:25 pm
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
Here is how I hold my sandpaper strip
PostPosted: Tue Apr 26, 2016 10:32 pm
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Thanks guys.
Brad Hall
Mystic Dawg Guitars
PostPosted: Wed Apr 27, 2016 6:15 am
We have tried all types of abrasive on our drum sanders and without question Zirconia (80g) works the best and more importantly lasts three or four times longer. I recommend taking the time to design your sander to use standard abrasives if for no other reason to take the advantage of the Zirconia, seem the choices with HL are very limited and expensive. Good suggestion above for the mechanical fasteners, there are others on line.
http://www.woodworkingshop.com/product/pe68080/
Ken Cierp
PostPosted: Wed Apr 27, 2016 12:44 pm
First name: Big
Last Name: Jim
i use 1/2" strip of duct tape and go around drum at both ends . requires knowing where NOT to run board through .
PostPosted: Wed Apr 27, 2016 1:13 pm
Actually I used 1" filament reinforced packaging tape on a shop made unit many years ago -- I got the idea from Grizzly since this was how it was held in place on one of their models. Maybe still is?
Ken Cierp
PostPosted: Wed Apr 27, 2016 4:01 pm
City: Tyler
Same here but I get away with the Stew Mac binding tape. Has never let go and easy to pull off.
PostPosted: Fri Apr 29, 2016 9:00 am
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
I use the velcro backed sand paper (hook & loop) and got from "onlineindustrial" supply. Come to think of it, you could probably just run a band of masking tape around the drum in several places then coat with superglue and roll your sandpaper around that. Then the only thing stuck to the drum is the masking tape.
PostPosted: Sat Apr 30, 2016 5:05 pm
First name: Jay
Last Name: Gordon
City: Port Townsend
State: Washington
Zip/Postal Code: 98368
Grizzled sells a kit to convert a drum sander to hook & loop. I used it to successfully convert my 16" drum sander. I strongly recommend it. To
First name: Jay
Last Name: Gordon
City: Port Townsend
State: Washington
Grizzley, that is.
PostPosted: Sat Apr 30, 2016 7:49 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
Also, supergrit.com
Users browsing this forum: Chris Ensor and 24 guests
